callmeclean
Jan 31, 2014Novice
Not detected and can't enable.
I have tried the A6200 Adapter on 3 different computers (Windows 7, 8 and 8.1) and different USB ports on each and I just cannot get it working. When plugging it in, it gives a long flash then a quic...
Retired_Member
Jan 31, 2014What's left to try. Read the post from other users who have same problem. USB devices shouldn't be this difficult to install. If you cannot install it on 3 different PC's I would say it's a bad adapter or a adapter you cannot install which then is useless.
Return it!
