callmeclean
Jan 31, 2014Novice
Not detected and can't enable.
I have tried the A6200 Adapter on 3 different computers (Windows 7, 8 and 8.1) and different USB ports on each and I just cannot get it working. When plugging it in, it gives a long flash then a quic...
sdvp
Oct 15, 2014Aspirant
New here. I have a similar problem. A6200 works ok when plugged directly into pc, but I need to use an active extension cable and when I do, no networks are detected. Adapter shows up in network and sharing center, but is disabled and cannot enable. I have tried 3 A6200 adapters 2 new and 1 refurbished, same result. I had an A6200 a while back that worked with an active extension cable but dropped it in the ocean so I know they used to work.
The extension cable is new and I have a netgear n900 that works fine with it.
Can anyone suggest a long range usb adapter?
