MrCarterMSA
Feb 24, 2017Tutor
On Networks N150MA-199NAS driver not available
I have an On Networks N150MA-199NAS wireless USB dongle. I tried finding a driver and the On Networks site referred me to Netgear. When I type in the product on Netgear it can't find it. I called the...
DarrenM
Mar 03, 2017Sr. NETGEAR Moderator
Here is the support site for that product
https://www.netgear.com/support/product/WNA1000M.aspx?cid=wmt_netgear_organic#download
DarrenM
- MrCarterMSAMar 04, 2017Tutor
Thank you, DarrenM, for taking the time to reply. Since I mentioned in my post that I tried that driver, to no avail, I'm a little confused as to whether referring me to that page is
1. just a polite way of saying that if that driver doesn't work it's a case of "oh well, then I guess you're out of luck" or if
2. I didn't make it clear in my post that I had already gone to that page, downloaded and applied the driver and the driver didn't recogmize the presence of the On Networks N150M-199NAS device, so there might possibly be
a. some way to get another driver that MIGHT work, or
b. some trick I could try so that the WNA1000M driver will recognize the On Networks N150M-199NAS device.
Can you let me know which is the case?
Thanks.
- JamesGLMar 08, 2017NETGEAR Employee Retired
Hi MrCarterMSA,
What is the OS of your computer? Possible reason why it won't work is the OS no longer supports the driver of the adapter.
- MrCarterMSAMar 09, 2017Tutor
I have tried the driver on Win XP, Win 7, and Win 10. I get the same results with each.
