arkadio's avatar
arkadio
Panasonic TX-P42VT30E
Which WiFi adapter is compatible with Panasonic TX-P42VT30E?
    • JamesGL's avatar
      JamesGL
      NETGEAR Employee Retired
      Hi arkadio,
      We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
      If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
      JamesGL
      Community Team
      • arkadio's avatar
        arkadio
        Hi James,
        could you recommend adapter compatible with exactly this tv type?
        I couldn't find exactly this type on the adapters list.
        will the one you have recommended (WNDA3100v2) work with TX-P42VT30E?
        Best Regards,
        Arkadio
