irishdude
Jun 24, 2016Follower
Security Key Location
Where can I get the security key?
VE6CGX
Jun 24, 2016Master
Security key is created when you configure the router or it is default value if you did not change it. On the router at wireless config. page.
If you want to connect adapter either you have tyo enter the key yourself when asked during set up session or use WPS if it is available.
JamesGL
Jun 29, 2016NETGEAR Employee Retired
Hi irishdude,
Contact your routers brand to get the security key of your wireless network.
- VE6CGXJun 29, 2016Master
Wait a minute, why OP has to ask manufacturer for security key? There may be a default one but user can change anyway he wants per security protocol.
- JamesGLJun 29, 2016NETGEAR Employee Retired
Hi VE6CGX,
I am just suggesting the OP if ever he is still unable to locate the security key of his wireless network. You have given him instructions to check on the router itself or the wireless configuration page of the router so my suggestion is if ever the OP still unable to locate it.
