BUZ
Oct 26, 2015Aspirant
Strange dns query from netgear adapter
I just started using a netgear wireless adapter on one of my windows 7 desktop machines and noticed a google dns query being sent (after I enable the adapter). Does not do this if using an ethernet connection. Is this normal for the wireless usb adapter to send google dns query?
- BUZAspirant
Hello,
When I check via dnsleaktest.com I see my isp DNS, confirmed via my wireless adapter that the dns is not set to use anything else, checked ipconfig /all in CMD and I see 192.168.1.1. Checked router setings and it's not set to use google dns (only isp).
When I run wireshark and enable the adapter (netgear wna1100) I immediatly see a two google dns querys every time then random ones every so often. I though that maybe it had something to do with automatic updates being enabled so I disabled updates however still does it. When I disconnect the wireless adapter and plug in ethernet cable I do not see the google dns querys so I assume it has something to do with the netgear adater?
- BUZAspirant
Any ideas???
