rsalinger
Nov 08, 2012Tutor
Stuck at 54Mbps
I setup my R6300 a couple months back and have been using it in conjunction with the N900 USB adapter and getting pretty reasonable speeds. I recently got the A6200 adapter and connecting to the same...
rsalinger
Nov 13, 2012Tutor
I've tried connecting on both the 2.4GHz and 5GHz bands both yield the same results. As mentioned, the 5GHz band will go upwards of 166Mbs but it won't with this adapter.
For this setup I'm one floor up and a room over. Not a very far distance. I just can't seem to cross the 54Mbs speed with the AC adapter, but the N900 works fine!
