rsalinger
Nov 08, 2012Tutor
Stuck at 54Mbps
I setup my R6300 a couple months back and have been using it in conjunction with the N900 USB adapter and getting pretty reasonable speeds. I recently got the A6200 adapter and connecting to the same...
Mark_K
Dec 29, 2012Tutor
Aurora420 wrote: I know this is probably not ideal, but can you try connecting with that same system (or at least same adapter / similar setup), in the same room? This way you can see if the adapter and driver is working properly, or maybe it's just a advanced driver setting wrong in the driver properties?
Did you perform this test yet?
If you are having low singals than try this test.
and get back to us.
