rsalinger
Nov 09, 2012Tutor
Stuck at 54Mbps
I setup my R6300 a couple months back and have been using it in conjunction with the N900 USB adapter and getting pretty reasonable speeds. I recently got the A6200 adapter and connecting to the same...
JayDubWill
Jan 01, 2013Aspirant
I found the solution to at least my problem. For whatever reason the setting under Advanced/Setup/QoS "Enable WMM (Wi-Fi multimedia) settings" was unchecked. Checking this immediately changed the connection speed of my A6200 connected PC from 54Mpbs to 702Mbps. It also increased the speed of every connected wireless device from to ~72Mpbs or greater. I confirmed that it's this setting by disabling it again and saw an immediate drop in all connected wireless device connection speed.
