rsalinger
Nov 08, 2012Tutor
Stuck at 54Mbps
I setup my R6300 a couple months back and have been using it in conjunction with the N900 USB adapter and getting pretty reasonable speeds. I recently got the A6200 adapter and connecting to the same network, I'm limited to connecting at only 54Mbps. If I switch back to the other adapter, the speeds go up.
I'm running Windows 8 and using the latest Windows 8 Beta driver.
Any insight as to what's going on?
- jmizoguchiVirtuosoWMM is necessary for achieving higher Mbps.
If you go Wikipedia and you can read about WMM - While this solved the connection issue, when transferring large files to my NAS, it only transfers around 512/728kbs (even though my connection is around 525Mbs). While using my N900 adapter I would get around 25MBs transfer.
Any thoughts? - VV00DyAspirant
jmizoguchi wrote: WMM is necessary for achieving higher Mbps.
This may be true for the A6200 because it fixed this issue for me but this reason is crap.
I have a laptop with a Killer Networks Wireless-N 1202 which connects to my Netgear R7000 Nighthawk ac router at 5Ghz just fine at full speed of 300Mbps with WMM disabled. The A6200 won't go past 54Mbps like this but clearly it's not a protocol limitation rather than a limitation of Netgear products.
I've played with this a bunch of different ways with both devices sitting on the same desk and the Netgear products just don't perform as well.
