Unfiltered
Apr 17, 2015Novice
The A6200 Connection Problems
I've been experiencing the A6200 problem of not connecting sometimes after waking from sleep mode or a computer reboot. Unplugging the USB cable and plugging it back in again usually solved the probl...
Phil6200
Apr 19, 2015Novice
For my A6200, i went into it's Properties - Advanced settings and changed the "Minimum Power Consumption" from ENABLED to DISABLED.
I did this once before along with other changes i saw another person did, but this time started with this and it worked, so i did not change anything else.
I can't recall what the others were or the forum in which i saw the other suggestions. Good luck & reply about any success if possible!
