KarlBradley
Sep 29, 2016Aspirant
Universal wifi adapter WNCE2001
Hi All
Have watched some youtube videos and read description but before I buy this can someone help please.
I have a router in house and wanted to extend its wifi. By ethernet. So I thought this may be the ideal product.
I do not want to connect the adapter to a TV downstairs for wifi etc.
I want to plug an ethernet adapter into the back of my router and then plug this ethernet cable into the WNCE2001 and put it somewhere in my house for better wifi coverage. I cannot move my router.
Will this product do this ?
Thank You
Karl
Hi KarlBradley,
Try our NETGEAR extenders which will extend the wireless network of your main router.
http://www.netgear.com/home/products/networking/wifi-range-extenders/
JamesGL
Community Team
- KarlBradleyAspirant
Hi again after doing some research......
I think what I need is a wifi extender with access point.
Do not think this product acts as an access point.
Would that be right?
Thank You
- JamesGLNETGEAR Employee Retired
Hi KarlBradley,
The device is a wireless receiver only and will not broadcast wireless signal. You can make wired device go wireless using the adapter.
JamesGL
Community Team
Hi KarlBradley,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
Hi sorry for delay.
So I want to run a cable from my fibre optic router (which has really bad wifi) to an access point near the middle of the house that is going to give out a really good wifi signal.
What Netgear access point would you suggest please? I am not internested in a router and trying to configure it as an access point I just want something very simple to set up.
I cannot move my fibre optic router and even if I could I would not as the wifi signal is so bad.
Also the cable I use would this be an ordinary ethernet cable, from an ethernet port on my router to the access point or does the access point have a different input for the cable?
Many thanks
Karl
