GuyVdB
Dec 30, 2016Initiate
USB N300 Mini Adapter
Hello, I bought a Netgear N300 WIFI USB Adapter. I inserted the CD in our computer. It did not appear on the screen, but it was available and I could open it. Then the content appeared on the scree...
- Jan 18, 2017
Hi GuyVdB,
Go to the link I have provided and search for the model number of your adapter then download the driver instead of using the CD.
JamesGL
Jan 02, 2017NETGEAR Employee Retired
Hi GuyVdB,
Download the driver on the link below.
GuyVdB
Jan 04, 2017Initiate
Dear James,
nowhere I found an answer to my question: I inserted the CD in our desktop computer. It did not appear on the screen, but the CD was available and I could open it.
Then the content appeared on the screen. But when opened it... no 'autorun.exe' appeared (as mentioned in the 'instriuctions guide'); only 'autorun.inf' & autostart.exe'.
So I couldn't go on...
What's wrong?
Thx for helping!
Guy
- JamesGLJan 18, 2017NETGEAR Employee Retired
Hi GuyVdB,
- JamesGLJan 24, 2017NETGEAR Employee Retired
Hi GuyVdB,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
