kBhushan
May 25, 2020Aspirant
USB WiFi Adapter - No Internet Connection
Hello Folks, I recently bought A6210 USB wifi adapter. The driver (Netgear Genie) was successfully installed and it detected my SSID. When I connect to any of 2.4 or 5G networks I cannot access t...
michaelkenward
May 26, 2020Guru - Experienced User
kBhushan wrote:
When I connect to any of 2.4 or 5G networks I cannot access the Internet.
What happens when you try?
How are you connecting?
How do you know that it isn't Windows getting in the way? Have you tried running its network troubleshooter?
kBhushan
May 26, 2020Aspirant
Hi Michael,
I am connecting via the dock provided in the box to a USB 3 port on my PC. (I tried without the dock as well)
The troubleshooter says it did not find any issues.
I did get in touch with NG chat support yesterday and we tried to solve it but no luck. I was advised to replace the device. However, I tested it from a win 10 laptop today and it worked fine. So, I am sure that the device is not faulty.
As you can see in the attached snapshots, Genie says it is connected. When I check on my wifi router (Tenda AC1200) I do not see any entry for my PC. Windows says 'Not connected - No Internet'.
ipconfig says the media is disconnected:
>ipconfig
Wireless LAN adapter Wi-Fi:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
I tried all older version of Genie but no luck.
Tried disabling my Kasperksy Internet Security too but again no luck. Somehow something is preventing it from getting an IP from the router.
