Jonesarob's avatar
Jonesarob
W9CE 3001
Hello, is there an eqivialent to the netgear wireless internet adappter WNCE 3001? I wish to connect a CCTV system to the internat via the router. Therefore looking to find an adapter (plug & play), ie with no drivers (CD) to set up.
Many thanks in advance.
  • JamesGL's avatar
    JamesGL
    Dec 13, 2017
    Hi Jonesarob,
    We only have the following wireless adapters without drivers needed for installation.
    WNCE2001
    WNCE3001
    WNCE4004
    • Jonesarob's avatar
      Jonesarob
      Thank you for reply, though as I understand the W9CE 3001, did not have a driver.  It was confirgued to your router direct, then was then inserted into the device. which then connected back to the router via wifi. Therefore no need for down loading drivers. Therefore was asking is there anything out there that is similar.
      • JamesGL's avatar
        JamesGL
        NETGEAR Employee Retired
        Hi Jonesarob,
        WNCE2001
        WNCE3001
        WNCE4004
