ot221268
Jun 20, 2015Aspirant
Where is the Bridge Mode?
Can anyone tell me where the bridge mode is?? It should be.......Advanced tab > Advanced Setup and click Wireless Settings but my login screen does not have an option for "Other operating mode". F...
Stobbart
Mar 19, 2017Aspirant
Thank you for the quick answer. How do I force to obtain IP address? I would like to connect a gaming router to d6200 and use it as only modem
- TheEtherMar 19, 2017Guru
Disconnect the gaming router from the D6200 then re-connect it.
Note: If your ISP uses PPPoE, PPPoA, L2TP etc., then you will need to set this up on your gaming router.
