ot221268
Jun 20, 2015Aspirant
Where is the Bridge Mode?
Can anyone tell me where the bridge mode is?? It should be.......Advanced tab > Advanced Setup and click Wireless Settings but my login screen does not have an option for "Other operating mode". F...
xDredgex
Jun 22, 2015Novice
Assuming R6300.....maybe v2....
Once logged in to the Admin console, click the "Advanced" tab > Advanced Setup > Wireless Settings > at the very bottom is "use other operation mode" > Enable Bridge mode is hidden under this > place a check next to "use other..." and it should appear.
With some of the older routers, it was always there, but if you had a popup blocker enabled on your browser it seemed to make it.....not appear. Disabling it mitigated that.
