ot221268
Jun 20, 2015Aspirant
Where is the Bridge Mode?
Can anyone tell me where the bridge mode is?? It should be.......Advanced tab > Advanced Setup and click Wireless Settings but my login screen does not have an option for "Other operating mode". F...
Fairytail
Jun 22, 2015Virtuoso
I believe you have a D6200 which is a modem. Wireless bridge is not available for this unit but you can set the modem to bridge mode. Which means that the device will be used as a modem only and you need to have a router to do the configuration.
Check page 130 of the manual.
http://www.downloads.netgear.com/files/GDC/D6200/D6200_UM_17Sept2014.pdf
