Netto29
Aug 15, 2022Follower
Wi-Fi adapter
Has anyone had success using a Netgear Wf-Fi adapter for MacOS 12.5?
Aug 16, 2022Guru - Experienced User
which wifi adapter?
You're not likely to find much on here but what many do is find what chipset is used for the adapter and google for that specific chipset and a driver. Thats about the only chance you have if the supported version doesn't support it.
