ZeroC00l
Mar 06, 2017Luminary
Wifi Speeds Differ
So got an odd strange issue. We just got 100mbit/5mbit cable internet. Both have the same USB Netgear Adapter Cards. The WNDA3100. Both in the same room about 10-12 feet and I get 114mbit while he ge...
- Mar 16, 2017
Hi ZeroC00l,
if you interchange the adapter, will he get the same result?
JamesGL
Mar 20, 2017NETGEAR Employee Retired
Hi ZeroC00l,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
ZeroC00l
Mar 30, 2017Luminary
Ya seems that it may be a wall or something, it's strange, some times he can reach high as 100+ other times its 80-90's low as 20 for a few moments. Yes I have tried changing out the adapter cards, same results.
I've been messing with them, there is a wifi router on his desk, I thought maybe that would create a problem, however he has it off and not even using it, and when he does have it on, same results.
I get 115 almost all the time. Very seldum I get below 90. Seems I am furthur away from the wireless router to. He most be around a lot of dead spot / zones. But if that's the case, then why isn't it doing it all the time? :)
