jmggmark's avatar
jmggmark
Follower
Dec 29, 2016
will my WNDA3100v2 N600 Wireless Dual Band USB Adapter work with my Samsung smart led TV?
  • Hi jmggmark,
    It does not support Samsung Smart TV. If your smart TV has ethernet port, try WNCE2001, WNCE3001 or WNCE4004.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi jmggmark,
  • JamesGL's avatar
    JamesGL
    Hi jmggmark,
    We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
