paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
Dustrega
Nov 07, 2015Star
Months. Take that word in. It has been MONTHS, since Netgear has had any tangible information or updates for this particular problem. It has been MONTHS, since I have seen any viable solution or suggestion to fix this problem. In case you don't know what I'm talking about, I would suggest looking here and here. You have taken my information, Netgear, and done what with it? Nothing, absolutely nothing. No word, no PMs, no credibility. I'll grant the guise of effort, but that is about all I will grant. I have been compliant with all requests for information and patience. I have been completely understanding that things like this take time, but MONTHS? There are issues with your hardware that have been around since Windows 8, and now with the release of Windows 10 the problem has resurfaced. Living proof that the problems you DON'T SOLVE will come around to bite you. Are you going to learn this time? Probably not, but as long as you got my money, and that of others, at one point or another you probably couldn't care less.
