paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
noboundaries
Nov 10, 2015Guide
Given the depth of this problem, and the information been given to NETGEAR, they appear to be non responsive.
They keep asking the same questions and enough information suppled to support without any doubt There is a real probelm here.
NO action has been taken and its been how long now??
Silence has been deafening...
Say something NETGEAR !!!!!
This and other hardware / firmware issues really make this a poor choice for networking solutions. Hello D Link..
