paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
Update4WinX
Nov 12, 2015Star
Has anyone tried using the A6210 since the new WindowsX update from today? I've been living in Win8.1 since stupid butthole Netgear never wanted to fix this issue in WinX. I would really like to be able to upgrade back, but I'd just bought this damn adapter a month before WinX was released.
- noboundariesNov 13, 2015Guide
I havent seen any updates ????, 1.0.0.32 is the firm ware that stuffed eveything up, for A6210.ever other a62xx
