paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
zipdrive
Nov 19, 2015Tutor
I have not tested the driver they have for 10 as the generic solution works for me fine. The question still remains as there is a version for 10 put out by Netgear and it hasn't been picked up by the repository, why? Are we going to make excuses for the biggest conglomerate on not staying on top of their driver database? 10 has been out for close to 6 months now. The OS didn't even bother seeing it as new hardware until I went into device manager. I'm just saying that its not 100% Netgear and its justified in saying the communication was lacking in this release.
