paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
LaurisSwe
Dec 18, 2015Initiate
Hey guys!
I had problems with A6210 on Windows 10 x64. My problem was that under driver installation process Wi-Fi adapter couldn’t be found. So my tips are that you look first at Networks Connections. There I couldn’t see wireless adapter, but I could see adapter in Device Manager. After many hours of trying different versions of drivers, googling and so on I was done! I thought (worse case) go back to Windows 7 but before that I did "Go to previous windows build" in Windows Update Settings. Oh man how happy I become :) After windows rebooted I've stopped in Wi-Fi adapter and directly I could see it in Network Connections. Then removed it, installed standalone 0.34 driver for Windows 10 and then I was done! 1 minute installation when it goes well and 2 days of frustration to find the problem. So guys, my problem was latest build of Windows 10! Hate Microsoft for that, because my other Wi-Fi adapter couldn't be found either and that’s why I bought Netgear.
Hope it helps for someone!
JamesGL
Dec 21, 2015NETGEAR Employee Retired
Hi Lauris Swe,
Please check your inbox.
