paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
paulj
Jan 26, 2016Aspirant
A few more observations in case these help Netgear.
I use Acrylic Wi-Fi Professional to view network performance.
I've tried using Acrylic with an A6200 (both V1.0.0.26-1, Win 10 version and V1.0.0.35), an A6210 (V1.0.0.34), and a Linksys WUSB6300. With the Linksys everything works flawlessly, it's rock solid for days and I can run speedtest.net and it's still solid. With the A6200, Acrylic (and Windows 10) stop seeing wireless networks after a few minutes. This is whether or not I have a wireless connection, so even when there's no data being sent or received wirelessly. If I make a wireless connection and run Acrylic with the A6200 or the A6210, when I run speedtest.net Acrylic will stop with a lost ellement error. This is 100% repeatable. Again, all of this works flawlessly with the Linksys.
I can use Acrylic to capture Pcap and send to Netgear if this will help.
By the way, I'm seeing much better sensitivity with the A6200 and A6210 than the Linksys when they're working, we just need the drivers fixed!
