paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
ed_di
Feb 08, 2016Aspirant
yes i doubt this will be fixed any time soon.. its already taken too long..
Anyway, its not perfect but i'm using a bat file executed from the task manager every minute to check for a network connection.
The bat file disconnects and reconnects the wireless adapter if the network is down. This will have to do until the drivers are fixed or I can figure out a better method.
good luck all ..
ps.....shame on Netgear and piss on MediaTek.... p.s. do not buy any wi-fi device that uses a mediatek chip /firmware .. Mediatek is primarily to blame for this lack of reponse/fix. This problem is not isolated to Netgear.
