paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
Icebear8
Feb 21, 2016Aspirant
i have not had the random disconnects on windows 10 with my 6210 BUT i am having trouble getting it to connect using the AC, i noticed today that since i owned this adapter and a nighthawk x4 that it's been using wireless N and not AC, i only noticed this because i bought a steamlink and having bad performance with it and now i know why.
