paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
Retired_Member
Feb 28, 2016I registered just to comment. I purchased this sorry excuse for a network card thinking it would boost my speed over an older D-Link USB adapter I am using. Boy was I wrong.
This thing constantly disconnects and I have to reboot, only for it to disconnect over and over and over and over. I cannot for the life of me understand how this product can be such a joke. Netgear is a large company with a ton of resources, and you are telling me they cannot get 1 or 2 people to fix the drivers for Windows 10?
This is pathetic. I will never be purchasing another Netgear product.
Cdr_Perkins
Feb 28, 2016Guide
Current status for me:
After manual installing the mentioned mediatek driver a few weeks ago and forcing Windows 10 to not take / update any other driver by itself, i have no problems anymore.
5ghz, no disconnect, no bluescreens and USB 3.0 (not 2.0 like with the netgear driver).
Marcus
- Retired_MemberFeb 29, 2016
Cdr_Perkins wrote:Current status for me:
Marcus
Which model do you have? I tried the Mediatek driver and got a BSOD on reboot, but I am using the A6200.
- MauleyMar 01, 2016Initiate
Also how did you force Win10 to not update the driver? That would be handy to know. Last time I tried the MediaTek driver I was not able to connect to 5G
- Cdr_PerkinsMar 01, 2016Guide
I have an A6210 wlan adapter.
I installed the mediatek driver (driver only) 5.1.25.0. and then plugged in the adapter. Windows 10 installed immediately another driver and overrides the mediatek driver.
After that i manually installed the mediatek driver via system control -> device manager.
Then i disabled the automatic hardware/device driver update function in Windows 10 (pro) via the group policies:
gpedit.msc -> policies local computer -> computer configuration -> admin templates -> system -> internet communication -> deactivate search for hardware (or device) driver on windows update -> click on "activate".
Sorry, i only know it in german so i hope my "english translation" was not too bad.
With that, Windows 10 doesn't change the drivers for devices / hardware via the update function anymore. This doesn't concern software for something like mice and keyboards for example, only "built in" devices.
But: now i have to search for hardware drivers by myself. But i think this is not a real problem ;-)
Marcus
