paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
cheeseds
Mar 18, 2016Initiate
I have had some luck with this the meat of the U2 issue seems to be a power saving mode I managed to fix my issue by going into Control Panel\All Control Panel Items\Power Options and selecting "High performance" (you may have to expand the "how additional plans" area) then clicking change plan settings, then "change advanced power settings" then selecting usb settings -> USB selective suspend settings and changing it to disabled
rvrby
Mar 24, 2016Tutor
It works like a charm, thank you cheeseds !!!!!!!!!!
