paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
Zachary0512
Jul 30, 2015Aspirant
What should we do if we have already installed the netgear drivers and "permanently" ruined windows 10's ability to access wifi networks? Do I have to revert back to windows 7, uninstall the adapter device itself, and then reinstall windows 10, and reinstall the device? Detailed instructions would be very helpfull
- paradeigmasJul 31, 2015Tutor
Okay, a few ways you can fix the problem:
1. System restore Windows 10 prior to driver installation, then go to step 7.
If System Restore is not available:
2. Backup your files
3. Right click on This PC and see if your Windows 10 is "Activated," if not, activate it to register your hardware ID with MSFT so that your computer becomes permenantly activated for Windows 10.
3. Go to Start -> Settings -> Recovery, Restore, Reset
4. Reset Windows
5. Do not keep anything
6. Start
Once complete:
7. Windows should now be able to find Wifi Hotspots, but don't connect yet. If no networks are listed, go to step 2.
8. Go to the intel link above and install your Chipset Drivers for Windows 10.
9. Reboot
10. Open Wifi Connections list, click on the one you would like to connect to.
11. Click "Connect"
12. It will ask for your password, don't type anything, and run to your router and click the WPS button.
13. It should be connected and functional properly now.
If above instructions did not work for you, I'm sorry as this is the process I used to solve the issue on my system. Good luck.
- DWow315Dec 10, 2015Aspirant
Hello there: I too am having the same problem. Did you resolve the issue? I'm currently unable to connect to wifi but had already gone through the installation process already. I have since removed the programs/drivers and tried the chipset installation fix to no avail. I seem to be at a standstill at this point. Did you by any chance find any fixes? Thanks for the help.
- FoomanchooDec 11, 2015Aspirant
I have Windows 10 Home/64-bit (via upgrade) and was successful with the latest Netgear driver A6200 Software Version 1.0.0.26-1 (Supports Win8.1 / Win10) found here: http://kb.netgear.com/app/answers/detail/a_id/24877
I did the standalone installation then plugged the adapter in and Windows recognized it immediately. I was up and running in less than 5 minutes. I'm also using the adapter with Connectify and it worked flawlessly. Call me lucky but I haven't encountered any problem whatsoever so far (fingers crossed).
- GrandjammerJan 15, 2016Aspirant
This worked for me, as a windows 10 fresh install. http://kb.netgear.com/app/answers/detail/a_id/24877
I also did the standalone installation and when I plugged my adaptor in it was instantly recognized and hasn't cut out once, whereas before I would be lucky to go half an hour without having to unplug and replug-in the adaptor.
