paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
x2mjokada
Jul 31, 2015Initiate
Hi,
I also had the unfortunate luck of installing the Netgear drivers during my upgrade to Windows 10 and had issues with wifi freezing up the system. Wish I would've seen this thread before upgrading to Win 10.
Anyway, the way I fixed this problem was by rebooting my system into SAFE MODE. Once in SAFE MODE, I went into the DEVICE MANAGER, looked for the A6210 adapter under NETWORK ADAPTERS, right-clicked on the adapter and uninstalled. I also checked the box to uninstall the drivers for this adapter. Once the adapter was uninstalled from the system, I rebooted back into Windows with the adapter still connected. As soon as I got back into the Windows 10 desktop, I was able to click on the Wireless icon in the system tray with the system would no longer freezing up, and finally showing me a list of available networks to connect to.
The problem I am still having though, is that I can only see the 2.4GHz networks and not my 5GHz network which I was previously using with no problems in Windows 8.1 before the upgrade.
Does anyone know how I can fix this so that the WiFi adapter can see and connect to the 5GHz networks without installing the NETGEAR drivers that cause Windows 10 issues?
Thanks
UMDTERPS
Aug 01, 2015Apprentice
I boot in safe mode, but NONE of my keyboards will work...so now I'm stuck in safe mode./
- UMDTERPSAug 01, 2015Apprentice
I used this method:
http://www.7tutorials.com/4-ways-boot-safe-mode-windows-10
Now I'm permantely stuck, OMG.
- AngryWifiManAug 01, 2015Guide
Try removing your keyboard and putting it back in.
That the firs thing I tired. The keyboard works for login, but fails after boot. I even tried a PS/2 keyboard same issue. I don't know what to do...
Seems like your USB drivers are playing up. Might want to do a fresh install of Windows and remember to install the Intel Chipset drivers to eliminate them as a source of error.
