paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
Solus
Aug 01, 2015Initiate
After 2 days of headache over this mess of an adapter I figured out the fastest way to get this working. These files are for manually installing the drivers.
Download this file from here :https://drive.google.com/open?id=0B0YLhDgxgUO3VGVQbERVMVJZOHc
-Unzip file
-Go into device manager
-Right click on the a6200 and then select update driver
-Select browse my computer
-Navigate to where you unzipped the download
-Select the driver folder
-Done!
This adapter has been a nightmare to install in every version of windows. Hope this helps someone.
AngryWifiMan
Aug 01, 2015Guide
With Chosey's fix I still get BSoD and driver errors during heavy bandwidth utilisation and torrenting. Will be trying Solus' method tomorrow (after I've tested system stability thoroughly).
