paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
paradeigmas
Aug 10, 2015Tutor
I have accepted the Mediatek's raw driver as the solution to this problem. Unfortunately for AMD users this will not work properly for you. You must wait for Netgear to push out the Windows 10 driver.
DaveyG
Aug 11, 2015Guide
Thank you for the replies. Looks as though I'll have to sit and wait for Netgear to update the driver for my 6210. I can connect via an alternative method for the time being.
