paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
dug_less
Aug 17, 2015Tutor
UMDTERPS, This user of an A6210 has found a working solution. I have posted a few times in this thread how i was able to resolve my issues with the wifi adapter. I found that the most current MediaTek driver, and some changes to the adapter properties in the driver settings have me working flawlessly. I can't speak for everyone, but I was able to resolve the problem and have shared this information in this forum thread.
stavers
Aug 17, 2015Aspirant
dug_less wrote:UMDTERPS, This user of an A6210 has found a working solution. I have posted a few times in this thread how i was able to resolve my issues with the wifi adapter. I found that the most current MediaTek driver, and some changes to the adapter properties in the driver settings have me working flawlessly. I can't speak for everyone, but I was able to resolve the problem and have shared this information in this forum thread.
But unfortunately that solution does not appear to work for user with an AMD processor - only Intel.
Mine is working as a 2G adaptor with the standard Windows 10 drivers but nothing more.
