paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
tthomas1947
Aug 20, 2015Aspirant
Further to my last comment- Network settings was totally screwed. Couldnt identify network but said adapter was ok. Reboot still didnt work even just using inbuilt wifi so finally had to go back to restore point yesterday.
Thats all my testing done until a proper fix is found!
steve1954
So, does anyone know of an AC adapter (any make) that works well with Windows 10? I just want to work without all the interruptions.
