paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
UMDTERPS
Aug 20, 2015Apprentice
Netgear relased a new driver today 5.1.22.0. I finally finished my PC rebuild and it appears to work. I am working from home tomorrow so I will let anyone know if there is any issues like dropped packes, pc sleep issues, etc.
Keep in mind I am using a intel based CPU and Motherboard.
http://downloadcenter.netgear.com/en/product/A6210#searchResults
steve1954
Aug 21, 2015Aspirant
Tried the new driver but it seemed to be for the A6210 adapter and I have A6200.???
