paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
Babylon5
Aug 21, 2015NETGEAR Employee Retired
TECK1015, Netgear are very actively working to resolve all issues identified in this thread, so all the adaptors named in the title are receiving attention.
dug_less
Aug 21, 2015Tutor
Is the new Netgear driver connecting @ USB 3.0 spec? Previous drivers all connected @ USB 2.0 spec. Could someone verify if the new driver connects at USB 3.0 speed. Thanks. I'm currently using the MediaTek driver with no issues and it connects at USB 3.0 spec.
- zmaniaczAug 21, 2015Guide
Running at 3.0 near as I can tell. WIndows isn't giving me any messages stating it could be running faster.
- UMDTERPSAug 21, 2015Apprentice
How do you check if it's running at the USB 3.0 spec?
- dug_lessAug 21, 2015Tutor
Google usbtreeview and download the tool. It will identify at what speed your usb device is connected.
