paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
DarkNeuron
Aug 22, 2015Tutor
Is the new Netgear driver not just the repackaged Mediatek driver?
Does Netgear even have any control over the drivers?
The Netgear installer still sucks. It loops forever in the "insert wifi adapter" step. I have to cancel that step, and "update drivers automatically" from the device manager to properly install the drivers. Wish companies would stop BS installers and just supply the drivers for power users.
But I digress... If these are just the mediatek drivers, I expect more intermittent packetloss on my system. Even yesterday the wifi adapter seemed to crash completely: The windows wifi list was completely empty (usually has loads of wifi in the area).
Question, the release notes mention:
- Always set U2 mode in ETRON & ASMedia USB 3.0 Host control
I actually have an Etron USB3 host controller, but you don't mention where you change this. Is it a bios setting? Doesn't appear to be a driver setting.
tthomas1947
Aug 22, 2015Aspirant
Improved but not fixed packet loss.
Changed D6300 5G channel to 600Mbps operation and now can load smaller test files ok (200MB) but still fails on 1G files downloaded simultaineously.
No expert on TCPIP protocols but using MS Network Monitor I see all ok until i start getting lots of Fast Re-transmits and the downloads fail.
Adapter is connected to USB 2 port as older laptop but as I'm on a 34Meg fibre broadband that shouldnt be a problem.
I got the A6210 as I had the D6300 router so trying to avoid this sort of issue. Didnt see any problems on win 7 but didnt try any big test files.
- UMDTERPSAug 22, 2015Apprentice
tthomas,
What is the site you are using for test downloads? I would like to see if I have the same issue.
Thanks
- dug_lessAug 22, 2015Tutor
Have you tried running traceroute to find where the packet loss is happening? You might want to check and see exactly where your packet loss is coming from.
- DarkNeuronAug 22, 2015Tutor
Well I'm pinging my router, so it's pretty clear where its coming from.
