paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
Upizmeov
Aug 22, 2015Aspirant
So I had nothing but trouble with my A6210 when I upgraded to windows 10 from windows 7.
I had the same freezing and then complete inability to see any wifi networks. Even some blue screens.
I finally managed to get Wondows 10 up and running but the A6210 would not do anything...even with the latest fdrivers that everyone had suggested. Until: I decided to uninstall the drivers yet again and try one last reinstall (good thing I had another computer available to get the drivers! Anyway once I installed as a standalone driver (without the genie) things began to work.
Just wanted to mention this to anyone trying to get their adapter to work.
Hope it may help someone.
