paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
TheBinaryX
Aug 23, 2015Initiate
Not sure if this problem is just me.
If I update using the updated .32 drivers for the a6210, my network works fine, even on 5ghz connection, to my knowledge at least.
However if i restart my PC or if my PC wakes from sleep i'm forced to REINSTALL the drivers (Standalone) to make it work again.
EVERY TIME.
AMD Based system
I've even FRESHLY installed windows 10, does NOT fix
zmaniacz
Aug 24, 2015Guide
After a few days of stability on the new drivers, I'm back to the dropped packets and 3000+ms packets to my router. Getting new wires run on Wednesday, so not going to worry about it anymore. Good luck to the rest of you.
