paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
Pakitos90
Aug 25, 2015Aspirant
I have netgear A6100 But there aren't new drivers for windows 10...it's a great problem because a Great society as Netgear is Not ready to a new operating system. I Hope in the next days we'll have new drivers.
Maz97
i see that netgear have updated their drivers for the A6210. i am considering buying this adapter. does anyone know if the new drivers ( v 1.0.0.32) has fixed the issues with this adapter and win10?
Thanks.
