paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
Update4WinX
Aug 26, 2015Star
Maz97 it depends on your processor type, I know Intel owners were having problems, but there was a Alton on either the first or second page for them. AMD users were not fixed by the 1.0.0.32 update.
It would do you justice to read the entire thread, I can't believe we are already to page 13.
My personal short answer would be find another company, I'd your wanting the speed(and this one had it) make sure to look for an adapter with the same speed ratings. KUDOS for doing homework before buying though.
