paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
ohbilly
Sep 06, 2015Aspirant
Thought I would share my positive experience. Windows update must have broken my Windows 10 A6200 as well. It was working fine after the upgrade and suddenly decided to stop connecting after a month. Here's what I did to fix it.
1. Install the latest Beta driver as of 9/5/15
2. It worked BUT download speeds seemed to be capped at 300k.
3. To fix this I right clicked the wireless icon in the systray (bottom right of screen), and went to "Open Network and Sharing Center"
4. On the left side click "change adapter settings"
5. Right click the wireless adapter, go to properties
6. Click Configure
7. Select the "Advanced" Tab
8. Scroll down to "AP Compatibility Mode"
9. Change it to "Broader Compatibility"
This resulted in my download speeds going immediately from 300k to 2000k (my limit usually).
I have an Edimax AC1200 wireless router. Don't know if there is some compatibility issues, but it fixed my problem nicely!
- ty880336Sep 06, 2015Aspirant
Hi ohbilly. Where did you get the latest beta driver for A6200? 1.0.0.35 version just not working for most people.
- seanvreeSep 16, 2015Tutor
ohbilly wrote:Thought I would share my positive experience. Windows update must have broken my Windows 10 A6200 as well. It was working fine after the upgrade and suddenly decided to stop connecting after a month. Here's what I did to fix it.
6. Click Configure
I don't have the "AP Conpatibility mode" ??
- douga54Sep 17, 2015Star
So here's what happened to me. I downloaded the free Windows 10 upgrade. It went thru the install, but before the install completed it killed my A6200 so I couldn't even download any fix that might be available. I finally got the Netgear Beta driver for the A6200 Windows 10. It allowed me to see available networks but it would not let me login to my encrypted wireless home network, wouldn't accept my encryption key. After several re-installs I gave up and went back to Windows 7. Everything works now. Netgear has been no help. I see many other Netgear users having problems with Windows 10 drivers and I am in no hurry to go thru this again. I guess I will stick with Windows 7 until I find a wireless network adapter that is known to work well with both Windows 7 and 10. Frustrating.
