paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Aug 01, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
Babylon5
Sep 01, 2015NETGEAR Employee Retired
DarkNeuron,
Have you followed the instructions as linked to in post 132?
http://kb.netgear.com/app/answers/detail/a_id/29802
This process has been tested by Netgear using a variety of computers and found to work in all cases, otherwise it would not have been made publicly available. However as I posted early in this thread, it is very difficult to account for all hardware and software configurations and Netgear recognise that some people may still have issues. The only way that Netgear can work to resolve remaining issues is if people provide some detailed feedback, post 133 for example provides nothing and seems to assume that the instructions are a simple ‘uninstall and reinstall’ process, there is no detail to work with in that post.
Netgear are keen to resolve this issue for all people, and are very willing to work with individuals to nail down specific issues, this can only be achieved if people are willing to provide detailed feedback. Christine has offered to help individuals via PM in post 132, and I will also try to offer that level of help if people want to contact me.
Joshuaderriere
Oct 21, 2015Aspirant
Dumb question, but I'll ask anyway - If I uninstall the Netgear drivers and do not have access to the Interent other than via a Wi-Fi connection, how do I download the new drivers?
