paradeigmas
Jul 30, 2015Tutor
Windows 10 (A6100 A6200 A6210) Installation Heads Up
As a heads up, DO NOT install Netgear's driver package for your A6xxx device on Windows 10. It permanently removes Windows 10’s ability to access the WiFi Connections list. Instead, use the defa...
- Jul 31, 2015
For problems with the windows 10 included driver with the a6210 (e.g. no 5ghz networks visible) just use the latest driver from mediatek (5.1.21.0).
It is the newer version of the driver that came with windows 10 and with it i can join my 5ghz wlan, which wasnt able with the old one!
The chip in the A6210 is a Mediatek MT7612U.
Joshuaderriere
Oct 21, 2015Aspirant
Thank you for your response. Unfortunately, my daughter already uninstalled the drivers per the instructions from a previous post. Do we have any options for downloading the needed drivers other than moving and connecting her computer to an Internet connection using an Ethernet cable? Thank you for your help.
Babylon5
Oct 22, 2015NETGEAR Employee Retired
Download using another computer to a USB memory stick.
- DaveyGNov 04, 2015Guide
I have now currently given up with trying to get my A6210 adaptor to work on Windows 10.
The adaptor conflicts with other USB hardware on my system.
I am fortunate in that I have a range extender (used to connect other wired devices) in close
proximity to the PC so I am currently using a Network cable as an alternative.
The range extender is used exclusively for connecting the wired devices. I have disabled
the wireless functionality on the extender.
