ralice
Jan 15, 2014Novice
Windows 8.1
Does either the A6200 or the A6100 adapter work with Windows 8.1?
IrvSp
Jan 16, 2014Master
ralice wrote: Does either the A6200 or the A6100 adapter work with Windows 8.1?
I just installed the A6200 on Win8.1. Works, no problems, and the router is the Netgear R7000 Nighthawk. Genie says it is connected at 175Mbps though, it is on the 5Ghz channel and I think it should be a lot higher. Don't trust Genie though, app has some problems. Unfortunately Windows in the Network and Sharing center's Status on the device reports the same connect speed?
