ralice
Jan 15, 2014Novice
Windows 8.1
Does either the A6200 or the A6100 adapter work with Windows 8.1?
IrvSp
Jan 17, 2014Master
searay wrote: USB 3 should enable you to connect at 800 or more while USB 2 would be around 390 from what I remember. Your 175 seems low. I don't understand why they don't state that in the brochures any more. .
I don't know what happened today. This morning I rebooted the router, power off and on. Then looked at the A6200 Genie, connection speed was 866Mbps. Windows device status confirmed the same speed.
12 feet away from the R7000 router in the same room directly across from it. Why not more, don't know why...
