mturonek's avatar
mturonek
Follower
Nov 13, 2016
Wireless Adapter
My LG Smart TV needs a wireless adpater to connect to wifi.  I purchased the AC600 adapter and the installation CD is not working on my MACBook Pro.  I am not sure the steps I need to take to make this adpater work if I even bought the right thing?
  • Hi mturonek,
    The adapter only works with Windows based OS computers and not compatible with Smart TVs.
    JamesGL
    Community Team
    • JamesGL's avatar
      JamesGL
      NETGEAR Employee Retired
      Hi mturonek,
      JamesGL
      Community Team
    • JamesGL's avatar
      JamesGL
      Hi mturonek,
      We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
      If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
      JamesGL
      Community Team
